I was getting a tool table error with the latest version. The problem was that one of my comments contained a quote character which broke the parsing. I rewrote the parsing to isolate the image name first, and then the comment. This will now allow a quote in the comment.
I modified the int CEditToolFile::LoadFile(CString File) to this:
int result,i,Revision=0;
CString Comment,Image,s;
int ID,Slot;
double Diameter,Length,Xoffset,Yoffset;
CStdioFile f;
if(!f.Open(File, CFile::modeRead|CFile::typeText))
AfxMessageBox("Unable to open Tool Table file:\r\r" + File);
return 1;
if(!f.ReadString(s))
AfxMessageBox("Invalid Tool Table file (line 1):\r\r" + File);
f.Close();
return 1;
s.MakeUpper();
if (s.Find("COMMENT")==-1 || s.Find("DIAM")==-1 || s.Find("LEN")==-1)
f.Close();
return 1;
if (s.Find("XOFFSET")>0 && s.Find("YOFFSET")>0 && s.Find("IMAGE")>0) Revision = 1;
int n,Tool=0,line=1;
while (f.ReadString(s))
// remove whitespace
s.Trim();
line++;
if (!s.IsEmpty())
if (Tool >= MAX_TOOLS)
AfxMessageBox("Invalid Tool Table file:\r\r" + File + "\r\rToo many Tools Max Allowed is 99");
f.Close();
return 1;
if (Revision==0)
result = sscanf(s,"%d%d%lf%lf%n",&Slot,&ID,&Length,&Diameter,&n);
Xoffset=Yoffset=0;
if (result !=4)
CString err;
err.Format("Line %d doesn't have 4 valid numbers",line);
AfxMessageBox("Invalid Tool Table file:\r\r" + File + "\r\r" + err);
f.Close();
return 1;
result = sscanf(s,"%d%d%lf%lf%lf%lf%n",&Slot,&ID,&Length,&Diameter,&Xoffset,&Yoffset,&n);
if (result !=6)
CString err;
err.Format("Line %d doesn't have 6 valid numbers",line);
f.Close();
return 1;
s.Delete(0,n);
Comment = s;
//remove beginning and ending whitespace
Comment.Trim();
if (Revision==0)
Image = "";
PutTool(Tool,Slot,ID,Length,Diameter,Xoffset,Yoffset,Comment,Image);
Tool++;
BOOL bImageSuccess = TRUE;
BOOL bCommentSuccess = TRUE;
//first isolate our image name
if(Comment.Right(1) == '"')
Comment.Delete(Comment.GetLength()-1,1);
i=Comment.ReverseFind('"');
if (i!=-1)
Image = Comment.Mid(i+1);
Comment = Comment.Left(i-1);
Comment.Trim();
bImageSuccess = FALSE;
if(bImageSuccess)
//Isolate our comment
if(Comment.GetAt(0) == '"' && Comment.Right(1) == '"')
Comment.Delete(0,1);
bCommentSuccess = FALSE;
if(!bImageSuccess)
CString err;
err.Format("Line %d doesn't have matching quotation marks for Image",line);
f.Close();
return 1;
if (!bCommentSuccess)
CString err;
err.Format("Line %d doesn't have quotation marks for comment",line);
f.Close();
return 1;
Tool++;
f.Close();
// Blank out others
for (int i=Tool; i<MAX_TOOLS; i++)
PutTool(i,0,0,0,0,0,0,"","");
m_nTools=Tool; // remember how many tools defined
return 0;
Eric
